Differential cross member - NCRS Discussion Boards
  • Bob I.
    • November 9, 2006
    • 265
    Are their other methods, to remove the rubber cushions from the cross member other than using a press. I took the original cross member to a shop and they mutilated it.
    Bob
    • 43245
    Re: Differential cross member
    Bob
    Bob-----
    Did they bend back the tabs before trying to press the cushions out? In any event, using a press to remove them is the only practical way. It may be possible to drive them out with a hammer, but I've never tried that and, I expect, it would be liable to cause more damage than pressing them out. If the tabs are bent back, the crossmember properly supported below the cushions, and the proper press tool used, I don't see why any damage should come to the crossmember.
    • Ron R.
      Infrequent User
      • January 31, 2007
      • 18
      I tried to drive mine out with a large hammer and gave up.
      They tend to get rust welded in place.
      Had to bring it to a Corvette specialist that had a press. He removed the old and installed the new without any damage to the crossmember.
      • Joel T.
        • April 30, 2005
        • 765
        Bob
        Bob;
        You need a press, to get the old ones out and candidly to get the new ones in... Where do you live? I'm in central NJ and have a press if that is of any help to you.
        Joel
        • Randy W.
          • October 23, 2007
          • 24
          I used lots of heat and burned out everything that wasn't steel. Worked good, if a little smelly.
          • Michael G.
            • January 1, 1997
            • 1251
            WD.....lotsa WD. Soak 'em good and when you think your done.....soak 'em some more. Mine came out w/o a press.
