C1 58 Trunk Irons - NCRS Discussion Boards
C1 58 Trunk Irons
  • Richard H.
    • February 28, 1985
    • 241
    C1 58 Trunk Irons
    For those of you who have installed aftermarket trunk irons, what is the best metal rod to create the studs and then prepare the irons for their installation so that they might be secured by the stock locknuts. Thanks.
  • Chuck W.
    • May 31, 2002
    • 257
    Re: C1 58 Trunk Irons
    Not sure about the aftermarket trunk spears but I use solid aluminum rod to repair broken mounting studs on originals. Carefully drill and tap holes where the old studs were and use a die to thread one end of a short piece of aluminum rod. Grind the other end round like the originals. Screw the rod into the threaded hole in the spear. After plating and installation you won't know them from originals. Use the correct speed nuts for installation.
