67 power window help - NCRS Discussion Boards
  • Jeremy H.
    • December 31, 1998
    • 260
    Just finishing up a restoration and I am having power window problems. New wiring, new switch, new relay. Motors won't work. I have used a test light and I get voltage to the motor plug when I move the switch up and down with the key on. I have even tried 3 or 4 other motors I have in the shop, none of them work. I checked the grounds and even ran another ground directly to the battery (-), still doesn't work. What should the voltage be at the plug? I think my repo relay was bad, put on an original used on and got a test light to work at the plug, which it didn't before with the new repo relay, but still no motor. Any ideas?
    Jeremy Hedges
  • Philip C.
    • November 30, 1984
    • 1117
    Re: 67 power window help
    Jeremy Hedges
    Jeremy, you didnt say if the motors worked out of the car, I assumed they did, the power windows reg. have a big spring so you have to put a bolt thru the arms to keep them from moving when removing the motors, maybe they are still bolted Phil 8063
