1970 Corvette Fan Switch - NCRS Discussion Boards
  • Mark H.
    Infrequent User
    • September 7, 2009
    • 21
    I am new to this forum and I have looked at many valuable posts and information regarding correcting my vacuum wiper door operation.
    My 1970 coupe 350/350 Hp has factory 4 season A/C. The blower switch, which is new does not work on the highest speed. This car has 35,000 original miles and I an wonder if there is an easy way to trouble shoot my issue. I replace the blower speed swithch, but that did not correct the problem.
    Can anyone offer me advice where to look next?
    Mark
    Mark Humphrey
    1970 Coupe
    Monza Red/Red Interior
    350/350 HP, 4 speed
    GM Proving Ground Vehicle
    34,600 original miles
  • Louis F.
    • September 30, 1991
    • 132
    Re: 1970 Corvette Fan Switch
    Mark, it's been a long time but I had a 1971 with A/C that had the same problem.I traced it to the drivers side fender near the alternator.There was a red wire with a fused link.A mechanic told me to check that fuse. Sure enough it was blown, changed the fuse and the high speed blower worked. Hope this helps.
    • Mark H.
      Infrequent User
      • September 7, 2009
      • 21
      Thank you Louis, I will do as you suggested. Thanks for a prompt response.
      Mark
      Mark Humphrey
      1970 Coupe
      350/350 HP, 4 speed
        • 6948
        Louis, if the fuse is a dead end, try the blower relay and it electrical connectors they tend to heat up over the years and spread open from the heat. relay is on side of a/c box pass side.
