Original Upper Radiator Hose Repair? - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    I have an original upper radiator hose that has a slight V shaped slice in the bottom of it. Just enough that a little trickle of coolant comes out of it. Is there any way to repair the hose or is it now a wall ornament?
    Dave
    • 6957
    Re: Original Upper Radiator Hose Repair?
    Dave, is the hose leak at the themostat end? sometimes a little corrosion get under that end hose and will cause a small leak, that tighting the clamp doesnt always work.
    • David S.
      • August 9, 2009
      • 595
      Edward,
      The slice is almost dead center on the hose. Just need it for a survivor car going through judging. Not for everyday use.
      Dave
      • Paul J.
        • September 9, 2008
        • 2091
        Dave,
        Come on, man. Are you going to run the risk of having your car either sit on the side of the road while you wait for a new hose, or having to be towed, or at the worst...warp a head just for an original hose?
        You can take this originality thing too far, you know.
        Paul
          • 6957
          Dave , Hoses Are A No Repair Operation, If It Leaking Anywhere Other Than Clamp Position , You Can Get A Reproduction Hose And They Judge Well. Paragon Sells Them.
          • David S.
            • August 9, 2009
            • 595
            Point taken. Thank you guys for the responses. Will get a new one.
            -Dave
