69 Wheel Lugs help - NCRS Discussion Boards
69 Wheel Lugs help
  • Jean B.
    • February 24, 2008
    • 49
    69 Wheel Lugs help
    can anyone show me what a 69 Wheel Lugs exactly looks likes ??
    and also can it be found to buy online ... like maybe like at paragon or any other online vette store ?? (that would be ncrs flight quality)
    JF
  • William C.
    • May 31, 1975
    • 6037
    Re: 69 Wheel Lugs help
    Might be easier to just point out that they can't be seen and aren't judged, so just about any replacement that will cross reference to the factory size and length would do.
    Bill Clupper #618
      • January 31, 1988
      • 43194
      JF
      JF----
      The attached photos show absolutely known original examples of a 1969 GM #3910340 lug bolt and GM #358501 lug nut. Were every single such lug bolt and lug nut used on Corvettes in 1969 exactly and precisely the same as these? I seriously doubt it. In fact, I know that many of the front lug bolts had a "TR" embossed on the outer end. The one pictured, from the rear spindle, did not.
      The 3910340 lug bolt was discontinued by GM several years ago. Dr. Rebuild and others sell replacements. As Bill described, these lug bolts cannot be seen once installed on the car, so what does it really matter if they are 100% correct in every way?
