Early 1956 Generator Bracket - NCRS Discussion Boards
  • Charles H.
    Infrequent User
    • April 1, 2004
    • 11
    Hi! I have a very early 1956 Corvette. This serial number used the Ram Horn, two stud exhaust flange exhaust manifolds ( part number 3725563) on both sides. My question is does anyone know what the generator bracket system looks like that must be used with these manifolds because they do not have brackets cast into the manifold like the second casting version used later in 1956. That manifold was part number 3731557.
    Any help would be appreciated!
    Best regards,
    Rick
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Early 1956 Generator Bracket
    Best regards,
    Rick
    • Charles H.
      Infrequent User
      • April 1, 2004
      • 11
      Thanks Roy,
      That picture down in the lower right tells it all. Should I look for parts numbers in the 1955 Parts Manual for the V8 engine?
      Thanks again,
      Rick
      • Roy B.
        • February 1, 1975
        • 7044
        Thanks Roy,
        Thanks again,
        Rick
        Sorry I dont know
        • Jimmy B.
          • July 31, 1980
          • 584
          Contach fellow NCRS member Michael Anderson
          Jim Blakely
          • Michael A.
            • June 30, 1986
            • 68
            Hi Charles,
            Call me, I can help you with the generator bracket.
            Later Mike Anderson (317)729-2418
            • Charles H.
              Infrequent User
              • April 1, 2004
              • 11
              Roy,
              Have a great day and thanks for your help!
              Best regards,
              Rick Hale
              • Charles H.
                Infrequent User
                • April 1, 2004
                • 11
                Hi Jim,
                Thanks, I will contact Mike as soon as possible.
                Best regards,
                Rick
                • Charles H.
                  Infrequent User
                  • April 1, 2004
                  • 11
                  Hi Mike,
                  I am currently away from home, but will call tonight or tomorrow.
                  Rick Hale
                  • Michael A.
                    • June 30, 1986
                    • 68
                    Hi Charles,
                    I tried to contact you at the office number you had given me earlier, but you were out. I have not heard back from you regarding the generator bracket. If you still need it give me a call. If not please let me know as I am going to put it up for sale in the driveline. Thanks and have a great day.
