70 Radiator Support - NCRS Discussion Boards
70 Radiator Support
  • Bill L.
    • February 1, 2004
    • 1403
    Re: 70 Radiator Support
    Based on #3748358 it appears that the washer is also used on clutch pedal to push rod assembly.
    Bill
    • Bill L.
      • February 1, 2004
      • 1403
      Resurrecting an old thread.
      What are the specs on Gm Washer p/n-3748358?
      Thanks, Bill
      • Rich C.
        • January 1, 1994
        • 383
        #18
        This washer #3748358 is used in several other places! On my '73 (perhaps and hopefully your '70) it is used (according to a.i.m.) Attaching upper spare tire tub to chassis, 2. evap. (charcoal) canister bracket to fenderwell. It would still be great if dimensions were posted, I went through my A.I.M. and painstakingly entered every piece of hardwares part # on a spreadsheet, then had computer 'resort' in numerical order, gives a common usage of fasteners. However there was an incredible amount of 'single usage' hardware!
        '73 LS-4 454, owned 21 3/4 years
        Otter Creek Copper Ale currently on tap!
          • 15606
          #19
          Not too likely ha has an evap canister on his 1970. That only came with the NA9 option in 1970.
          • Bill L.
            • February 1, 2004
            • 1403
            #20
            Thanks Rich.
            Just so happens I have my spare tire carrier out. Washers are there so I may be able to post dimensions. I knew it was used elsewhere like on the clutch pedal assembly but that one was a little tougher to get to
            Bill
