65 Big Block Cylinder Case - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    Has anyone seen a 3855961 case on a 65?; if you read the JG on the 65 this cylinder case number is discussed in that section.
  • Mike M.
    • May 31, 1974
    • 8404
    Re: 65 Big Block Cylinder Case
    only 961 block i've seen in a 65 vette had its last "1" chiseled off and a JB weld "2" inserted. i believe the 961's were pass car blocks. don't ever recall seeing a 961 4 bolt block but haven't seen them all. mike
    • Pancho T.
      • July 31, 1993
      • 238
      I have never seen one in a vette.I did have a couple of 4 bolt 961 blocks.Both were dated past July of 1965.So either service use or '66 passenger car use
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Mike McCagh (14)
        only 961 block i've seen in a 65 vette had its last "1" chiseled off and a JB weld "2" inserted . i believe the 961's were pass car blocks. don't ever recall seeing a 961 4 bolt block but haven't seen them all. mike
        Agree wrt no 4-bolts in a '961. But related, in Colvin's Chev-by-the-Numbers ['65-69] interesting Chevrolet blueprints of the 3855961 on pgs 59 and 60. The bottom view drawing shows a 4-bolt with the following note: "OMIT 10 OUTBOARD TAPPED HOLES AS SHOWN". So I guess a person could convert one to a 4-bolt main block by adding the 10 holes for the 5 main bearing caps. Just skip the JB weld . Colvin also says the '962' 4-bolt had thicker cylinder walls.
        Hey Pancho, do your later '961's have the two webbing gussets above the timing chain cover and on the back like these (off a mid-May cast 961) ?
        • Pancho T.
          • July 31, 1993
          • 238
          Wayne,
          no they did not have the two webs.....I wished that they had the aluminum heads and tripower likw the one in your picture
          • Anthony S.
            • April 30, 1998
            • 156
            So why would the JG even talk about the 961 case? Here is the the JG states: "casting number for all 396 engines is 3855962. ......check for reinforcement gussets located above the timing chain cover at approximately 11 and 1 o'clock. .... Some 3855961 cylinder cases have reinforcement gussets; however, all 3855962 cylinder cases have reinforcement gussets. ...."
            • Rich P.
              • January 12, 2009
              • 1361
              I have seen many 962's with out the webs. I was looking for a block for my 396 car 25 years ago and did not buy several correctly dated 962's because they did not have the reinforcement.
              Rich
