65 Tele Rag Joint - NCRS Discussion Boards
65 Tele Rag Joint
+ More Options
Posts
  • Sheldon S.
    • March 1, 1999
    • 482
    65 Tele Rag Joint
    Could someone describe what the coupler looks like for a tele column or if they ave a picture i they could post it. Also is there any casting number on either flange?
    Sheldon
    • 43297
    Re: 65 Tele Rag Joint
    Sheldon
    Sheldon-----
    Search for a thread entitled "66 L36 Harmonic Balancer, Steering Coupler" by John McRae. In that thread I posted photos of the coupler you seek info on.
    The coupler pictured may not be exactly, in every way configured like the coupler that was originally installed. However, this is a 65-66 with tele coupler.
    • Jim D.
      • 2885
      Sheldon
      Send me your e-mail address so I can attach pictures. My 65 has the tele wheel and the coupler has never been touched.
      Jim
      • Jim S.
        • August 31, 2001
        • 730
        This is a scan of the engineering drawing for the 1965-66 C2 Corvette Telescoping Column Flexible Steering Shaft Coupling Assembly 5692974.
        It indicates that the coupling assembly should have been painted black before it was shipped from Saginaw Steering Gear. I don't know if your information would prove otherwise. Interestingly, the flex couping assembly drawing for the standard (non-adjustable) column does not have a paint specification.
        Jim
        • Jim D.
          • 2885
          Jim,
          I sent you some pics. You can tell that it was definately painted black at one time (long ago).
          Jim
