1957 E Brake light switch - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    I have attached 2 pictures of an emergency brake light switch which came with my car parts.
    Is it the correct configuration?
    When I twist and release the handle it hits the switch bracket.
    It seems that the offset in the bracket should be on the opposite side.
    Of have I just been laying under the dash of my car to long?
    All advice will be appreciated.
  • Michael L.
    • July 31, 2005
    • 562
    Re: 1957 E Brake light switch
    Looks like my '55 switch, should be the same.
    • Tom P.
      • April 1, 1980
      • 1815
      That's it!
      That little "bent over" tab on the end of the long flat arm is contacted, and pulled back, by the head of a pin in the E-brake shaft when the E-brake handle is FULLY released. This breaks the electrical circuit to the flasher unit.
      Exact same switch/flasher that is on my 56.
      • Steve H.
        • November 1, 1996
        • 118
        Bruce,
        I had the same problem on my 56. I was told that the car switch holder was opposite of the corvette switch holder. I found another one that had the offset on the opposite side and it worked like it should.
        Steve
        • Bruce B.
          • May 31, 1996
          • 2930
          Steve,
          Your response backs up my thoughts on the design of the switch holder.
          I think I can adjust it to work but I'll look for the correct part.
          Thanks to everyone for the info.
          Bruce B
