What does an Original D409 rotor look like?? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    This is what they have on eBay as NOS right now. The one I have seen that I thought was right looked different. This looked pretty basic to me.
    Thoughts and a picture would be appreciated.
  • William C.
    • May 31, 1975
    • 6037
    Re: What does an Original D409 rotor look like??
    Attached is a pretty good picture of a used one "from the day" Taken from above to show the tip length. One of the pictures I took for the "Restorer" article. Email me directly if you want a high-res version, as I have to reduce the file size to use it on this board.
    Bill Clupper #618
    • Larry T.
      • May 15, 2007
      • 404
      That looks like the one I have seen. So is the one I pictured a replacement? I have seen it in several places being sold as a D409.
      • William C.
        • May 31, 1975
        • 6037
        I'm not certain that the picture from the auction site has enough detail to make a determination. The plastic was the same on the D-409 and the D409R, the change was on the tip length. The originals had a mold number on them next to the "delco remy" logo. If original, it should come in the hard metal top "delco remy" box. I think you can see from my picture pretty well how much the tip goes past the plastic underneath.
        Bill Clupper #618
        • Chuck S.
          • June 30, 1991
          • 184
          I`ve been meaning to give you my kudos for the article on the D409 rotors. I`m sure that all of us who read it learned.
          GREAT JOB!!!
          • William C.
            • May 31, 1975
            • 6037
            Thanks, just a little tidbit I learned the hard way about 35 years ago.
            Bill Clupper #618
            • William C.
              • May 31, 1975
              • 6037
              Also might note that there is a "made in canada" version floating around that is supposed to be a D-409, but it doesn't meet the early "Goodguy" dimensions
              even though the tip lacks the "E" stamp. Some fellow in Chicago is selling them on the big auction site.
              Bill Clupper #618
              • Larry T.
                • May 15, 2007
                • 404
                My membership had lapsed and I did not get the last several Restorers. I am of course now signed back up. I ordered the Restorer archives on CD but did not see your article. When was it written? Can you forward me a copy?
                Larry
                • Chuck S.
                  • June 30, 1991
                  • 184
                  The person in Chicago selling the D409R rotors is our buddy from Chicago Corvette.
                  • William C.
                    • May 31, 1975
                    • 6037
                    The files are too large for the DB, if you send me a PM with your email I'll send youa PDF copy of the article with pictures.
                    Bill Clupper #618
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Not knowing about the difference in rotors and length of the electrical contact, after reading about rotors in the NCRS Driveline article I am going to inspect what rotors I have, in use and old removed ones to see what I have. Thanks
                      • William C.
                        • May 31, 1975
                        • 6037
                        That one was referenced in the article, not equivalent to the "goodguy" versions.
                        Bill Clupper #618
                        • John D.
                          • December 1, 1979
                          • 5507
                          You will find out that finding a NOS D409 in the old style box is not an easy task. Now as far as service replacements go the only ones (one) that I have seen that are identical to the old style come from Accel.
                          The ones that Standard made or make have an E and are the short tip.
                          Meanwhile Clupper old friend have you or any of your pals used a dyno to verify that there is in fact a noticeable difference between the short and long style "tip"??? Would be interesting if a drag racer noticed a difference. Maybe Dipstick (Is he still kickin?) and that cheater MD fru MD would try this test on their old clunkers they race with.
                          Enquiring minds wanna know. Being a pack rat I looked thru a ton of old D409's both DR and others. 99% are the short tip meaning they were made 1969 or later if I remember your nice article. But I did come up with a couple of used early D409's.
                          If you want to buy a new one gang check out Accel. Yes you might think Standard made or makes their rotor but if so why is the tip longer? JD
                          • William C.
                            • May 31, 1975
                            • 6037
                            When I measured an accell, it did not have the longer tip. ???
                            Bill Clupper #618
                            • Gene M.
                              • April 1, 1985
                              • 4233
                              I have been removing the rivet spring and metal strip on the rotors and repositioning it. I set it up on the distributor and turn it past a dial indicator to set to the "old" position. The difference is as much as .058" on the ones I "revised".
                              After finding and positioning the spring and metal I drill a new hole thru the spring metal and plastic rotor and install new rivet or small screw and nut. Afterwards I check it with the cap I plan to use. I have found that caps vary too. Some did touch the contacts in the cap but another cap had plenty of clearance, about .010" to .015". Must be a "china special". I guess one could make a new longer metal and save the drilling. I guess I'll try that next time, and save the drilling since it is difficult to keep and maintain the position with all three parts.
                              For flight judging I'm using Carlisle acquired caps for correctness, so I know they are USA made.
