Signal lever 1970 Corvette - NCRS Discussion Boards
  • Jim F.
    • April 7, 2008
    • 60
    This might be a good one. My NCRS Judging Manual shows turn signal lever for early 1970 Corvette should be gloss black plastic end with many grooves parallel to the stalk. However all parts catalogs show end as no grooves, grained pattern.Which is correct, what do I order? Thanks in advance.
    • 15616
    Re: Signal lever 1970 Corvette
    Does what they are selling look like the 1972 turn signal lever drawi9ng in the manual?
    • Jim F.
      • April 7, 2008
      • 60
      Yes it does, no grooves. Catalogs do not have one like judging manual saysa early 70 should have with the grooves.
        • 15616
        They are selling the product they have, rather than telling you that what they have is NOT correct for your car and losing a sale. If you call and ask they will likely fess up.
        My suggestion would be to schedule a trip to Kissimme, Florida, in January -- it is a nice show and swap meet in usually lovely weather. Alternately Carlisle, PA, in the Spring or Fall -- you just missed this one a month or so ago.
        There is a chance someone reproduces the lever you need and others may know of it -- I don't do so well at parts hunting. I prefer tech stuff.
        • Pat M.
          • April 1, 2006
          • 1579
          Jim - a couple of years ago I bought the grooved turn signal lever and teletilt lever from Corvette Central, I believe. They still show they sell the grooved teletilt lever:
          I'd be surprised if they still sell this but not the grooved turn signal lever, so I'd call and ask. And even if they do only sell this, maybe you can buy it and put this cap on a seperate turn signal lever. Good luck
          • Jim F.
            • April 7, 2008
            • 60
            Thank you!
            • Pat M.
              • April 1, 2006
              • 1579
              Jim - here you go, they call it a "blinker handle":
              The picture's not the best but this is the part number I used to get mine.
              • Richard R.
                • August 31, 1988
                • 98
                Pat and Jim, that lever you showed is for a t&t steering column. Jim's car is a standard column, they are different. I ran into the same problem with my 70 and called Trim Parts and I was told to send it back with my original and they would see what could be done. Within a week both levers came back with no charge. Hope this help
