looking for the correct 12V voltage regulator for a 55. in past discussions 1118825 and 1118826 were mentioned. in the ncrs judging guide only the regulators for 6v seem to be listed. what is the correct number?
55 voltage regulator
Re: 55 voltage regulator
The VR cover held on with two screws at each corner with red tag, also 12V horns had red plastic bushings
Little is covered for the 55, I guess because you dont see them vary often
you need an 826 for your 55. just went thru this issue with my 55 and both John Pirkle, ex-53-5 team leader dave ferguson and current team leader, dave brigham, state the soon to be revised 53-55 judging manual will list 826 as correct for the V8 55's. mike- Top
Mike your right I just looked at my 55 again and I thought I saw a 5 but I think was a 6 , hard to tell using a mirror ThanksLast edited by Roy B.; September 22, 2009, 12:20 PM.- Top
