Question on installing new oil pressure line in a '66... - NCRS Discussion Boards
  • Steven S.
    • August 29, 2007
    • 571
    I've got a new oil pressure line an correct fittings for my '66, but I am not sure how you install the fittings. The fittings did not come installed on the line so they just slide over the tubing. I assume there needs to be some sort of flare done to the end of the line once you slide the fittings on, but I am not sure how this should be done. Any help would be appreciated!
    Steve
    • 43295
    Re: Question on installing new oil pressure line in a '66...
    Steve
    Steve----
    These are a compression-type fitting. No flare is required or should be performed.
    • Bill I.
      • January 29, 2008
      • 554
      Also, make very sure you have the tube going into the gage bottomed out before tightening the fitting. Did you get the s/s tubing, I hope. Bill.
      • William C.
        • May 31, 1975
        • 6037
        Are the SS lines you refer to magnetic? Judges have been known to check for the correct copper=plated steel versions unless it's a bigblock, then they just look for steel....
        Bill Clupper #618
          Bill -
          I've never seen a stainless steel oil pressure line; doesn't sound like a suitable material for that application.
          • Steven S.
            • August 29, 2007
            • 571
            Oh man, I didn't realize it was that simple. The line is a "correct" reproduction '66 BB line, so no stainless here.
            Thanks for the advise!
            Steve
