Worn trans governor shaft grooves - NCRS Discussion Boards
  • Thomas G.
    Infrequent User
    • July 31, 2001
    • 3
    I'm in the process of having the trans rebuilt in my 1954(E), S/N E54S001926. The fellow doing the rebuild says the governor shaft ring grooves are worn/stepped and the governor has to be replaced. He has been unable to locate an acceptable replacement. Can the grooves be restored by some means? Is there a replacement part that will function properly? Is there a source for a new/rebuilt governor?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Worn trans governor shaft grooves
    There is a guy on e-bay once in a while selling PG parts,e-mail him, also a guy in the driveline that sells PG parts
