Trailing arms help - NCRS Discussion Boards
Trailing arms help
  • Wayne P.
    • January 23, 2008
    • 444
    Trailing arms help
    I have decided to get my trailing arms refurbished over the winter.
    before I have a problem not sure if they were ever looked at.
    Before I take them out should I reference the drive shaft yoke with the trailing arm spindle . (Sorry if I don't have the correct name.) example place a couple punch marks ? Or can the rear drive shafts be installed on either side. I would also make sure the u-joints are good at the same time. I will also make note of the shims.
    Any other advice on what to look for in advance would be helpful.
    Thanks in advance.
    1964 drum brake
  • Gary R.
    • April 1, 1989
    • 1799
    Re: Trailing arms help
    Make note of the shims,inboard and out to get back close but with new T/A bushings installed this will change.
    No need to witness mark the 1/2 shafts to flanges, those are not balanced and can go back either way. Look for crushed tubes near the yokes as a sign someone worked on them in the past. With the old joints out you want to check the yoke bores as well.
    This thread I wrote will help you as well
    Here is one on the T/A's
      • 43247
      Thanks in advance.
      1964 drum brake
      Wayne-----
      I would never re-use the u-joints, especially if they've been in the car for a long time. If even slight brinnelling is noted on even one of the trunnion bearing surfaces, the u-joint is scrap. I think you'll be amazed at just how bad the u-joints are when you get the shafts out and remove the bearing caps.
      • Wayne P.
        • January 23, 2008
        • 444
        Gary. Great advice . Do you still recommend Spicer ? I noticed the product number is 5-799x. Would this be the one to order. I can get hold of a lathe
        to make the fixture. THX
        • Gary R.
          • April 1, 1989
          • 1799
          Yes, I still only use spicers. They went up on price with the last sets I ordered for carlisle but the few dollars extra is still worth it- just don't break the rings. I still have the extra rings as well. Use 5/8 or 3/4 flat stock if you make a fixture.
          • Wayne P.
            • January 23, 2008
            • 444
            Gary. I called a local Cheve dealership and asked if they would look up the u-joint for the half shafts. He did the number flipped a few times. He said it was a spicer no grease nipple price 149.50 FOR ONE !!!
            I told him I could get a half shaft including u-joint for that.
            It is no wonder why I hate to go to a dealership for parts . Part guy agreed. he would knock 20 off. I think the average price would be 27$ plus.
              • 43247
              Wayne-----
              A GM dealership is definitely not the place to buy u-joints. However, there is one thing to keep in mind: Spicer makes several different series u-joints. The ones that come in GM boxes are the "top-of-the-line" and not usually the ones you get from a Spicer dealer or auto parts store. I THINK (but, I'm NOT sure) that Spicer even has more than one line of u-joints without grease fittings. The less expensive line looks somewhat like the original u-joints and has a standard, forged steel body. The more expensive line (and, I believe it's the one that GM sells under their part number) has a much different configuration. It's manufactured of forged, powder metal and, consequently, it's a lot stronger. Of course, as I say, the configuration of these u-joints is a lot different than original and, from that perspective, they might be less desirable from a "restoration" perspective.
              In any event, I think one can purchase any of the available Spicer u-joint lines for less cost from a Spicer dealer or auto parts store. However, if one compares the cost of Spicer's top-of-the-line u-joints from a Spicer dealer/auto parts store versus a deep-discounted price from a GM dealer (like GMPartsDirect), I think the price spread would narrow considerably.
              • Gary V.
                • March 1, 1997
                • 15
                Thanks in advance.
                1964 drum brake
                Wayne
                Looks like the info has been given on the shims and u joints but you should also take a look at the brake hardware, springs,Em cable, drum and cylinders while the arm is out of the car. It is a lot easier to replace these Items during the rebuild.
                Check also what the arm rebuilder is quoting to do. Generally the arm / bearing rebuild does not include any brake hardware and it is and extra charge. We have done a lot of these at www.Vtechcorvette.com
                Gary V.
                • Wayne P.
                  • January 23, 2008
                  • 444
                  I thought I would give an update. I got the a-arms off having to use a air chisel to cut the nut .
                  I didn't realize how bad both bearings were.
                  I marked the half shafts left and right.
                  The bolt was also driven out with the air chisel with a long punch attached.
                  I marked the shims ( look like originals with bolt hole. ) .
                  I t looks like I need new bushings in the strut. It was mentioned to mark the washer for re installation.
                  I think I will upgrade struts. VBP has a what looks to be a good set up.
                  I don't have a numbers matching car. Would it be advisable to replace drums with disks at rear ?
                  I replaced the front with disks and duel master with vacuum .
                  I was also thinking about replacing the rear spring with a fiberglass spring..
                  This car will be a driver .
                  My other question is the rear end yoke moves in and out by had. I guess I need to put a dial indicator on it to determine
                  end play.
                  Thanks for all the advice
                  Thanks Sorry for the long post.
                  • Gary R.
                    • April 1, 1989
                    • 1799
                    Wayne
                    If the pinion yoke moves in/out you have a problem. If you're referring to the side yokes then they will have some, over 050 is no good and should be checked to see if the yoke or posi is the problem.
                    I setup a 64 with Disc brakes last year, I can put you in contact with the fellow. He did all the research and selected the parts, I fit them for him. I had to do some minor machine work.
                    • Wayne P.
                      • January 23, 2008
                      • 444
                      Thanks Gary.
                      I will check end play of the side yoke. I have a starrett dial indicator with a magnetic base. Thanks for any contacts or info.
                      • Gary R.
                        • April 1, 1989
                        • 1799
                        No problem Wayne, you can call me with any questions and check my threads on DC for reference. Be sure the Mag base is secure. With the 1/2 shaft out you should be able to mount it and gently move the side yokes in/out. If you find 050 endplay it may not be the yokes. They would have to be removed to check. I just did a 72 diff where the problem of 090 endplay was in the posi case. Once I machined and fit the case with a 12 bolt cross shaft it was reusable and 1/2 the cost of a new loaded eaton. It also is a lot better then a new eaton.
