Ti , No Spark?? - NCRS Discussion Boards
Ti , No Spark??
+ More Options
Posts
  • Paul S.
    • June 30, 1982
    • 356
    Ti , No Spark??
    Car Ran Fine (66, 425hp)came Home Shut It Off. Now It Has No Spark. Tried A New (current Replacement Ti Box Module) Still No Spark. Also Checked Connections Etc. Could It Just Be The Coil? . I Know I Can't TRY A Non Ti Coil On A Ti Car , But Can I Try This Coil(ti) On A Non Ti Car And See If The Ti Coil Is Bad ??? I'VE GOT A COUPLE NON TI CARS I COULD TRY THE COIL ON BUT THE 425 CAR IS THE ONLY TI CAR I HAVE .
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Ti , No Spark??
    if you have chevy corvette shop manual it give the resistance reading you should see with a good TI coil
    • Michael H.
      • January 29, 2008
      • 7477
      Re: Ti , No Spark??
      Try this link. I posted a GM/Delco test procedure for TI ignition some time ago.
      https://www.forums.ncrs.org/showthre...69153&uid=1861
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Ti , No Spark??
        try this flow chart
        • Ken A.
          • July 31, 1986
          • 929
          Re: Ti , No Spark??
          Check the ohms resistance on the PU coil, if 0, then it's probably open and your culprit.
          • Robert K.
            • April 30, 1996
            • 3
            Re: Ti , No Spark??
            I had a similar problem on my 67 small block TI, and it turned out to be a bad ground at the amplifier box. Removed the box, cleaned all ground connections and it runs perfect.
            • Doug M.
              • January 1, 1991
              • 68
              Re: Ti , No Spark??
              Paul,
              Make sure, where the engine wiring harness attaches at the firewall, is secure, clean , and a tight fit.
              Doug
