Excessive Clutch Cross Shaft Play - NCRS Discussion Boards
  • Jim O.
    • January 3, 2007
    • 11
    I need help to fix a cluch pedal that rattles inside the car in the lower rpm range. The problem is the frame to engine clutch cross shaft has excessive play - up and down and side to side at both ends, at the bellhousing ball and at the cross shaft tower ball. I don't see anything out of the ordinary more than what I consider to be normal wear on the pivot points. Are there supposed to be internal bushings of some sort in both ends of the cross shaft? Thanks for your help.
    • 43279
    Re: Excessive Clutch Cross Shaft Play
    Jim-----
    There are no internal bushings in the crossshaft for C1 Corvettes. I would say that if you have excessive play that there must be excessive wear on the ball studs and/or the inner surfaces of the crossshaft.
