Build date question - NCRS Discussion Boards
Build date question
  • D S.
    • March 1, 2005
    • 1551
    Build date question
    What is T0907LM date on engine pad? September 1968 for a 1969 427?
    Scott Sims
    Texas Chapter
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Build date question
    Originally posted by D Scott Sims (43568)
    What is T0907LM date on engine pad? September 1968 for a 1969 427? ...
    Sounds right to me. 'LM' was a '69-only suffix; 390hp & 4sp. Assembled 7th of Sept 1968.
    • John C.
      • January 1, 2005
      • 616
      Scott Sims
      Texas Chapter
      Scott
      Since 69 was a longer then usual model year you'll need to know the block casting date to determine if it is Sept. 7th 1968 or 1969.
      John
      • D S.
        • March 1, 2005
        • 1551
        It's VIN 194679S101713, a convertible.
        • D S.
          • March 1, 2005
          • 1551
          And where would the block casting date be found, on the driver's side rear near the bellhousing?
            • 15606
            On that early 1969 it is likely down by the starter -- slightly in front of the starter on the side of the cylinder case. Of course that only works if the cylinder case is age appropriate for the car. Look on the driver's side rear of the cylinder case too -- since you don't know what you have.
            • Michael D.
              • June 30, 1996
              • 536
              ...It's VIN 194679S101713, a convertible...
              Check again. 69 would be 194679S701713.
              • D S.
                • March 1, 2005
                • 1551
                You are correct. Thanks for bringing that to my attention. I assume by the 01713 number that the '69 was probably built in late '68.
                • Steven G.
                  • November 17, 2008
                  • 348
                  According to birthday book, #1763 was built on 9/18/68. Steve
                  • Jean C.
                    • June 30, 2003
                    • 688
                    It's having a birthday tomorrow! Cake and ice cream all around .
                    Best regards,
                    • D S.
                      • March 1, 2005
                      • 1551
                      Best regards,
                      Hey, Charlie...how goes it? Thanks for the birthday greeting but it's not my car. Darn it.
                      Are you going to be in Killeen in October?
                      Scott Sims
                      Texas Chapter
                      • Jean C.
                        • June 30, 2003
                        • 688
                        You bet I'll be at the Lone Star Regional in Killeen in October.
                        If you have not yet registered, do so and join us.
                        Best regards,
                        • D S.
                          • March 1, 2005
                          • 1551
                          Best regards,
                          I'll probably leave that gas suckin' '70 at home and go to Killeen in my old less-than-economical Blazer. Some day I will let the judges have at my Corvette.
                          I may be there on Friday or Saturday but for sure one of those days. I've got a Richard Fortier 1st Design exhaust tip to show to the 1970-1972 owners.
                          • D S.
                            • March 1, 2005
                            • 1551
                            Steve, it's 01713.
                              • 15606
