67 Hazard Flasher Capacitor at Fuse Box - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Does anyone have a picture and description of the correct 1967 hazard flasher capacitor at the fuse box. Thanks.
    Kirk
    Re: 67 Hazard Flasher Capacitor at Fuse Box
    Kirk
    Kirk -
    Nope. There is no capacitor used for the hazard flasher - only for the turn signal flasher.
    • Patrick T.
      • September 30, 1999
      • 1286
      Kirk -
      John, suppose you had a '67 with radio delete...would it have a capacitor or not? Thanks, PT
        Hint: there's no such thing as a 'radio delete' option. The base car came without a radio. All of the radio related RF 'hush up' capacitor components are bundled and called out with the U69 option defined at the end of the AIM.
        So, no radio, no RF capacitor on the TS flasher...just like the AIM defines.
        • Patrick T.
          • 1286
          Thanks for clearing that up Jack. What was I thinking?
          • Kirk M.
            • June 30, 2006
            • 1036
            Thanks.
            So, I need to understand something here. I get this NCRS criticism about my flasher and now I am not sure what the heck they are talking about. What controls the flashers? Is it the yellow unit on the driver's side radio side panel, or is there something else? Thanks.
            Kirk
            • Peter L.
              • May 31, 1983
              • 1930
              Kirk- The turn signal flasher is the unit mounted on the radio side panel (see Item 9, UPC 12, Steet B1 of the 1967 AIM). Pete
              • Kirk M.
                • June 30, 2006
                • 1036
                I've got it now. I thought there was a turn signal flasher at the radio panel AND a hazard flasher at the fuse box. The Hazard FLasher at the fuse box is what I'm trying to learn about. Which "model" would be appropriate for my 16,469 corvette built in April of 67. If I'm getting it right, it seems the embossed rectangular natural finish Tung-Sol 552 would be correct.
                Now all I need to do is find one!
                Kirk
                • Peter L.
                  • May 31, 1983
                  • 1930
                  Kirk - The Hazard Flashers used in 67 based on the S/N of your car, would either be the 552 Tung-Sol having the top embossed top w/ Tung-Sol, 552, etc and it would have a natural metal finish round can cover or the Signal-Stat 175 (as in Patrick's picture) having the top embossed w/ 175 & SIGNAL-STAT and it would have a green anodized rectangular box metal cover.
                  Pete
                    That's covered in your copy of the 1967 Judging Guide book. See Interior, Item 14, Under Dash.
                    TS Flasher= Non-DOT Yellow Plastic Tung Sol 323 or Non-DOT Signal Stat 145
                    Hazard Flasher= Non-DOT, natural finish, Tung Sol 552 or either a Non-DOT Signal Stat 170 (gold tone case) or non-DOT Signal Stat 175 (greenish tone case).
                    • Brian M.
                      • February 1, 1997
                      • 1840
                      Here's a pic of the gold one VIN# 7471
                      • Kirk M.
                        • June 30, 2006
                        • 1036
                        Thanks guys.
                        Kirk
