Info Needed: 1967 Conv #194677S121226 - NCRS Discussion Boards
  • Jeff M.
    • July 27, 2009
    • 67
    Hello, I am looking for any info past info on my 1967 Corvette Conv #194677S121226. Originally a 427, Marina Blue with White & Blue Int. It was owned by a Mr. Vanderbeck in NH. Any info would be greatly appreciated as it is about to undergo a body off restoration. Thanks in advance for any info. Jeff
  • Jean C.
    • June 30, 2003
    • 688
    Re: Info Needed: 1967 Conv #194677S121226
    Jeff,
    You should put this in The Driveline classifieds and you will reach many more members than using the TDB. Good luck with the search.
    Best regards,
    • Jeff M.
      • July 27, 2009
      • 67
      Good Idea, I will go ahead and place it in there now online, so it will make the next issue. Thanks Charlie, Jeff
      • Keith B.
        • March 7, 2008
        • 928
        if it means anything my dad owns a car 388 numbers off your car. sounds like a great car
        • Jeff M.
          • July 27, 2009
          • 67
          Cool, it is a neat car as is your dads I'm sure, can't wait to have it restored. Thanks Jeff
          • Keith B.
            • March 7, 2008
            • 928
            Its just a L79 coupe but its been top flighted a couple of times at chapter meets.
            • Tom H.
              • November 30, 1993
              • 3440
              Hi Jeff:
              I ran a title search and found title record for the car in Ohio. Info shows the car resides in Ohio County 55, which is Miami County. Right down the road from me!! If the car is, or was in the Piqua area, I bet I can find you some history on the car. Drop me a pm or email. I will be glad to help. Here's my office email. Use that. tom@budschevy.com I sent you a PM with the Ohio info. It will show a previous title number which will get you under way in your info search.
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Jeff M.
                • July 27, 2009
                • 67
                Tom, Thanks for the info. Anything I can build on helps. I will send you a pm. Thanks again Jeff
