re trim tag - NCRS Discussion Boards
re trim tag
  • Harry L.
    • December 22, 2008
    • 370
    re trim tag
    right now , these are the best pictures I have. I CAN SHOOT SOME MORE PICTURES LATER. THANKS. DUTCH How should the D look
  • Bob H.
    • July 31, 2000
    • 829
    Re: re trim tag
    looks like someone took steel wool to the plate to possibly clean off overspray. Maybe that is a good indication since I doubt anyone would paint a replacement and use something rough to remove the paint.
    Just my $0.02.
    • Ara G.
      • January 31, 2008
      • 1108
      Re: re trim tag
      Harry, you really need to get the Authentication book from the NCRS if you really want to verify the Trim Tag. It is chick full of pictures and knowledge. It is one of the most informative books I have. Regardless, that is exactly what I am looking for - a maroon with black leather interior. Nice car. GOod luck with it.....Regards. ARA
      • Wayne M.
        • March 1, 1980
        • 6414
        Re: re trim tag
        Dutch -- at first blush, I can't point to anything that says "repop". Maybe it was just a switch with another original.
        But for the stress marks (discussed in the trim tag book by Grenning/Sinor) angle lighting is best to bring up the relief. Check the '9' and the 'D'.
        Here's an example of a tag I rescued from a boneyard (someone had already sawed off the birdcage bar with the VIN tag 194675S101497, which I'd seen on a visit a year earlier). You can see corrosion spots from being exposed to the elements.
