Question/opinion needed 71 Chassis - NCRS Discussion Boards
  • Pete B.
    • February 22, 2007
    • 326
    I am in process of doing a body off resto on a small block coupe.
    I would like some opinions on the difficulty level of rebuilding the following parts myself or spend the $$ and getting them rebuilt or buying rebuilt/new parts. Please list from 1 to 5 (5 being most difficult) based on your experiances. All items worked and did not leak prior to resto start.
    Power steering pump
    Power steering control valve
    Power steering cylinder
    Steering box
    My my goal right now is top flight... maybe higher down the road. The car has limited upside so I can't be throwing money at things that I may be able to do myself. The car is a one owner 60k mile car 90% original but well worn.
    Thanks in advance!
    Pete
    Pete Bergmann
    2005 - 2013 C6 National Teamleader
  • Bill C.
    • July 15, 2007
    • 904
    Re: Question/opinion needed 71 Chassis
    Power steering pump
    if you are good with mechanical stuff and have a decent supply of
    tools, it is not to bad. Othrewise send it out for a rebuild. Check the
    DriveLine for NCRS service.
    Buy a new one. Keep the old one. Change out all the bolts and the end
    dust cap to the new one.
    Buy a new one and resuse the dust/grease boot.
    Steering box
    I would personally buy a new one, I did for my car and it was really a
    smart idea. They are a real bitch to take back out after the car is
    assembled. The rebuilt ones are a crap shoot depending on who did the
    rebuild. You could also send yours to a NCRS vendor for a rebuild.
    My 2 cents ....
    • Harmon C.
      • August 31, 1994
      • 3228
      The only part you have listed I repair is the steering gear box. I took a class at Bloomington years ago which made the job easy. Maybe you can find some good files on the internet with pictures on the rebuild. Bair's Corvette has the new seals. I did buy them from GM but the price went out of sight and they may be out of stock for good.
      Lyle
      • Chuck S.
        • April 1, 1992
        • 4668
        Originally posted by Pete Bergmann (47041)
        ...All items worked and did not leak prior to resto start.
        Power steering pump
        Steering box
        ...The car is a one owner 60k mile car 90% original but well worn.
        I'm assuming by "well worn", you mean the exterior and interior of the car were neglected...the mechanical condition of the components you've listed is pretty much unaffected by it's neglected appearance.
        Considering that the car only had 60K miles on it, and that you want to reduce the cost of the restoration, here's a novel idea: Do a cosmetic restoration to each component and call it good. Frankly, you can probably do the same for the transmission and differential; change the gear oil (or not) and do a cosmetic restoration of those as well. Sixty thousand is pretty low mileage for a frame off resto; my car had over 100K miles, and in retrospect, I wasted a lot of money going through everything.
        If those components weren't leaking, that says they still have the original lubricant inside. If they were well sealed, that lubricant is clean. Save yourself the money; without outside tampering, the parts will probably last longer too. Of course, you'll want to cap and seal the power steering components to keep dirt and debris out of the system until you reinstall with fresh power steering fluid. I would not change the lubricant in the steering gear.
        • Edward S.
          • February 23, 2009
          • 43
          Power steering pump
          Steering box
          Thanks in advance!
          Pete
          Pete, I rebuilt all those components on my 70 with no problems, access to air tools and a well stocked tool cabinet is a must, but well within reach if you have some mechanical ability , I would rate the job a strong 3 Ed
          • Pete B.
            • February 22, 2007
            • 326
            I get asked this a lot...60k why a frame off...we all know 60k miles on a 3 year old car vs 60k on a 38 year old completly different animal! ....the body took a small hit and was repainted poorly, exhaust system was changed but was falling off and wrong, rear bearings were replaced but must not have been done right as they can wobble 1/4 inch get the picture? It just seems everything I see needs some love, and since my labor is free, and I have no plan to sell, it will make me a better judge to do as much as I can. I hate sending things out bc nobody seems to take any pride...just got my block back with socket set screws in the block drains....the guy said oh we just throw that stuff away! At least he left my deck alone!
            Pete Bergmann
              • 3418
              Hi Pete,
              I dd a body-off restoration on a one owner, 46K, 71 small block coupe....
              for many of the reasons you stated.
              I spent WAY more HAPPY hours on the project than I thought I would, but was able to control the $$$.
              It turned out to be the car I wanted it to be.
              I think you're on the right track.
              • Chuck S.
                • April 1, 1992
                • 4668
                I get asked this a lot...60k why a frame off...we all know 60k miles on a 3 year old car vs 60k on a 38 year old completly different animal!..
                All too well do I know about the "animal"...no judgement of your decision was intended or any offense meant.
                My only intent was to advise you at that mileage, many of the heavy duty, wear components will not need immediate overhaul so why spend the money and time to go through them based on the car's appearance. But, if you think it will be satisfying, you can probably do all that work if you're technically competent. A copy of the 69/70 Overhaul Manual would be a good addition to your library if you don't already own it.
