Storag procedures - NCRS Discussion Boards
Storag procedures
  • Mike T.
    • October 8, 2007
    • 12
    Storag procedures
    I will be laying up my 59 corvette for several years. What are the proper procedures for long term storage and protection of the car and the engine.
    Thanks for the help
    Mike trinwith
  • John F.
    • March 23, 2008
    • 2409
    Re: Storag procedures
    Mike, I live in S-TX and would gladly take it for a spin every now and then for you. Not ever having to do this before, I would change all fluids and run the car for awhile, squirt some oil down each cylinder & put plugs back in, lube all the grease fittings, place on jack stands at proper points & take wheels off. If subject to freezing I would leave new coolant in the car and block and beak the upper hose loose. Others may chime in. Or as I said above, I'll drive it alittle for you.
    John
