Attn: Joe Lucia; Please settle friendly dispute - NCRS Discussion Boards
    • 11698
    Re: Attn: Joe Lucia; Please settle friendly dispute
    I see the Orange one came up in seconds also. I had to go to the garage, uncover the car and fight the AIR, and radiator hose to get a mediocre shot.
    A lot of interesting pulley stuff in all these shots.
    I take pictures to show the orange car owner. He lives in Japan, so I keep an album on Webshots for him to see progress on his car. "Master pics" of both cars are here on my computer.
    A few hours with a lift and a memory card and you too could have pictures at your fingertips.
    Patrick
      • 43290
      Originally posted by Graeme Beaupeurt (48035)
      Is this true for Big blocks also ?
      Graeme-----
      Yes.
        • 43290
        #18
        Originally posted by Larry Evoskis (16324)
        Joe:
        Must clearify: LT1 is for F-Car--Camaro Z28--. Shows clearly in the Camaro
        ASM that bolts are used. Got to assume both are the same--Camaro Vs. Corvette LT1. Looks
        like I am going to loose this argument with him--correct?
        Larry
        Larry-----
        I thought you were talking about Corvettes and that's what my response was based on. I don't know what the situation was for Camaro. Generally, though, I think that the bolt attachment was "phased out" beginning with 1969.
          • 43290
          #19
          Originally posted by Jeffrey Salz (13182)
          Joe:
          Just a small technical correction- early '69's had bolts not studs (page 331 of AIM note 6 staes that "nut dwg was a bolt" 11-7-68). My October '68 car is this way and it is a PAIN to allign all the pulleys and fan clutch and get the bolts started. Just my 2 cents.
          Jeff
          Jeff-----
          Yes, I would not be surprised, at all, that early 69's used bolts. 1969 was the change-over year, so especially for something like this, the change might have occurred after the start of the model year.
          For installation woes created by the lack of studs and use of bolts, simply install 2 studs and use them to get the pullies and everything aligned. Then, install 2 bolts in the other two holes. Finally, remove the 2 studs and install bolts. Done.
            Larry-----
            Joe -
            '69 Camaros used bolts - don't know when the attachment changed to studs on the Camaro, as '69 is where my "F"-body knowledge stops.
            • Jeffrey S.
              • May 31, 1988
              • 1902
              #21
              Joe:
              This is exacltly how I have been doing this for years. In fact I cut slots in the top of the studs to allow for an angled screw driver tip to remove a stubborn stud.
              Jeff
              • Kenneth B.
                • August 31, 1984
                • 2091
                #22
                Just to round out the discussion:
                My two Feb. 1970 LT-1'S have studs like Terry's
                KEN
