Aluminum rivet head shape - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    I'm replacing all of the underbody reinforcement plates and I've noticed that the original rivets head shape after they have been deformed at the factory are not very round. They are more like squashed stumps.
    I'm using a small air hammer with a tool that I've modifed using one of the vendors hammer tools as a guide.
    The head that I can make is a very nicely symetrically shaped round head that I think looks great but it's nothing like the factory shape.
    I think the factory rivet is held in more by expanding the shaft of the rivet than the head ( or lack of head).
    Anyone have any comments on this?
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 15646
    Re: Aluminum rivet head shape
    Expanding the shaft is the way steel rivets increase the strength of the joint. I'm not sure that is necessary in holding the underbody sheet metal to the plastic on the Corvette. It seems to me this is more important in skyscrapers and bridges than Corvettes. The upset head may be more significant in spreading the load on fiberglass. I seem to recall some illustrations of various joints in the front of the AIM. It might be worth taking a look at those illustrations.
    • Chuck S.
      • April 1, 1992
      • 4668
      First, cut the rivet to correct length for the AIM part number; you won't end up with a lot of material in the peened head that isn't supposed to be there. Second, I know that rivet guns are faster and easier, but I got good results by simply hand peening, with someone else bucking the flat round head using a 3 pound engineers hammer. Even then, your peened heads will be prettier and more symmetrical (over-restored if you like), because you don't have a boss checking on you to see if you're done yet. If you want them to look real, hold your riveting gun at a angle or kind of wallow it around while peening. (only kidding)
      Terry, from my observations, the flat round head of the rivet is typically on the fiberglass side, and the peened end is on the metal reinforcement or part side (I can see the spare tub reinforcement frame riveting as I type). I believe they did it that way to minimize any chance of damage caused by the rivet gun "banging" against fiberglass. The shaft expansion very definitely tightens the joint, but that simply may be an inherent by-product of the peening process rather than being necessary for the joint.
      • Steve L.
        • June 30, 2001
        • 763
        Originally posted by Chuck Sangerhausen (20817)
        First, cut the rivet to correct length for the AIM part number; .
        Chuck,
        Do you know what the length that sticks out of the assembly prior to peening over should be
        Steve L
        73 coupe since new
        Ottawa, Canada
        • Harmon C.
          • August 31, 1994
          • 3228
          The rule in the sheetmetal trade is the diameter of the rivet should stick through. I make each rivet this length with a special tool. Assembly line workers should have used what was called out in the AIM. What they used was what the stock boy dumped in the bin if it would work.
          Lyle
          • Chuck S.
            • April 1, 1992
            • 4668
            Originally posted by Steve Lischynsky (36372)
            Chuck,
            It varies considerably depending on the part number used for the joint, i.e. how many layers and thicknesses were being riveted. Go into Doc Rebuild's site; he once had a table there of GM rivet part numbers and the respective lengths. Doc Rebuild sells the longest shank length and you cut them to proper length using the chart. He used to sell genuine NOS aluminum rivets, but I don't know if the supply has been used up or not. I'm sure any repros of his would be very close to original (He made sure the buyer understood the deficiencies of wannabe repro rivets, so he knows his rivets well. )
              Paragon also has the correctly-configured soft aluminum body rivets.
                • 3422
                Hi,
                I put together a rivet list based on the AIM when I was putting my 71 back together.
                The large flat-head list obviously has the most descriptions.
                The first information in each line is the UPC, Sheet Number, and Item Number where the rivet first appears in the 71 AIM.
                The last page (cut in two) contains the 'rarer' rivets like the flat- head counter-sunk and the round head.
                I hope this info helps someone.
                • Steve L.
                  • June 30, 2001
                  • 763
                  thanks Alan
                  Steve L
                  73 coupe since new
                  Ottawa, Canada
