TH 400 Shift & Interlock Cable Parts Needed - NCRS Discussion Boards
  • Carr C.
    • March 1, 2004
    • 86
    I have a '70 LS5 Corvette with TH 400. I am looking for the shift lever that bolts onto the shift selector shaft at the transmission. The shifter cable attaches to this. I believe the part number is 3949083.
    It is not the bracket that holds the shift cable that bolts to the pan, but the little lever the end of the cable attaches to, and moves the selector shaft inside the transmission
    I also need the LOWER shift interlock cable bracket that bolts to the transmission pan (?) and holds the bottom end of the interlock cable and allows the cable to attach to the same pin as the shifter cable on the shift lever (see above).
    I think I undertand the set-up, and I've studied pictures in the parts manual. Any help would be greatly appreciated.
    Thanks in advance for your help.
    • 43290
    Re: TH 400 Shift & Interlock Cable Parts Needed
    Carr-----
    The shift lever was GM #3949083. The bracket was GM #3949085. Pacific Corvette (www.pacvette.com) has original examples of both parts available.
