Carter YH 2006SA carbs - NCRS Discussion Boards
  • David W.
    • May 31, 1990
    • 51
    1954 Corvette Carter YH 2006SA carburators
    Does the fact that the idle mixture screws have no effect suggest a cause??
  • Karl L.
    • February 1, 1977
    • 174
    Re: Carter YH 2006SA carbs
    David,
    Are you referring to adjusting the fuel to air mixture on each carb?
    If so and they won't change the mixture when turning the adjusters in or out... Maybe each carb has a blockage where the needle is and has to be blown or cleaned out.
    Sometimes an intake manifold leak will let air into the system, causing an adjusting problem on the carbs.
    Karl.
