Chaulk marks discovered - NCRS Discussion Boards
  • William M.
    • July 31, 1993
    • 390
    The underbody metal splash shields on my '73 big block coupe were rusty and a little bent, so I decided restoration was in order. When I removed them, I found chaulk markings underneath.
    On the passenger side, I found "716". I believe this is the Job #. I looked on my Build Sheet and I see in the upper left it reads "62-0716" - could this relate to the "716"?
    On the driver side, I found what appears to be "PW". I think this is where they would write "PB" to indicate power brakes. Could that "W" be a lazy "B" instead?
    Bloomington Gold 2011
    Corvette Magazine 9/11
    Bloomington Gold 2013
    Corvette Magazine 3/13
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12758
    Re: Chaulk marks discovered
    What about power windows?
    Rob.
    NCRS Software Developer
      • 3416
      Re: Chalk marks discovered
      Hi Bill,
      It's amazing how well that job number has survived on so many cars. The 'shields' really did their 'job'.
      Like Rob, I'd think power windows, too. Does your car have them?
      • William M.
        • July 31, 1993
        • 390
        Yes, my car has power windows, I thought that too. But this location under the driver side shield should have a "PB" for power brakes according to pictures in both the Dobbins and Licastro fact books.
          • 15601
          Your car has power brakes, Bill?
          • Roger S.
            • May 31, 2003
            • 262
            My 73 has the "PW" marking as well.
            There appears to be a chaulk marking above it also, but I have not been able to tell what it is. I have never looked under the passenger side heat shield - something for me to do now.
            Roger
              Yes - that indicates Schedule #62, and it's the 716th consecutive unit within that schedule group.
                • 15601
                John, then how does this relate to the oft told story of "500 units and the numbers rolled over to zero"?
                • William M.
                  • July 31, 1993
                  • 390
                  Great info. Thanks.
                  • William M.
                    • July 31, 1993
                    • 390
                    Roger
                    I don't know if two cars make a trend, but I guess it's "PW" for power windows. Strange it's in the place where logically you would expect "PB" for power brakes.
                      Terry -
                      During the C1 and midyear era, each "schedule" consisted of 500 units, and that same format (schedule number - unit number) appeared rubber-stamped on the "Corvette Order". I'm not a C3 guy, but the format William noted (62-0716) makes sense if the logic continued with more units in each schedule, although I don't know that to be a fact.
                      • Roger S.
                        • May 31, 2003
                        • 262
                        In the books mentioned, Dobbins & Licastros, the PB is above the shield not behind it. In the books there is no mention of what is behind the shield.
                        Roger
                          • 15601
                          On my 1970 behind the shield is PB & UA9. Sounds like there were changes in 1973.
