Got the November 09 Vette Magazine in the mail today, with a very interesting dyno test. They used a 327 with 461 / 2.02 heads, and a 30 30 cam. They compared dyno results switching a Holley 750 Street HP carb (in lieu of a vintage 3310) with a 7380 FI unit supplied by Chuck Smith. The results were 355 hp at 5,700 rpm / 366 lb-ft at 4100 rpm for the carb, and 364 hp / 363 lb-ft for the FI. Peak torque occurred at a higher RPM for the FI. The most startling result was from the cam switch:
"Before pulling the 327 off the dyno, we couldn't help but try to improve the output of the L76 carbureted combination with a simple cam swap. Mostly, we wanted to demonstrate just how far cam technology has come in the last 40-odd years. Would it be possible to improve power while maintaining - or even improving - idle quality and driveability? To find out, we installed an XS274S cam from the Comp Cams catalog. This solid flat-tappet unit offered a 0.501/0.510 lift split and a 236/242 duration split (measured at 0.050). This represented a slight increase in lift but sizable drops in intake and exhaust duration (18 and 12 degrees, respectively) as compared with the original Duntov grind. Nevertheless, the more-aggressive ramp rates of the Comp unit increased the power output of our carbureted combination from 355 hp and 366 lb-ft to 370 hp and 380 lb-ft. The "milder" cam also improved power throughout the rpm range, offering improvements of as much as 20 hp and 20 lb-ft of torque over the factory Duntov stick."
