'72 lower ignition shielding - NCRS Discussion Boards
  • Kurt G.
    • April 30, 2005
    • 343
    I'm in the process of replacing the missing lower exhaust shielding and am not sure where all of it attaches. I've looked at the AIM and it appears it attaches with the exhaust manifold bolts. Is that correct? All of the lower shielding was removed from mine by a previous owner, so I have no clue where it might attach. And, I'm asking without having looked under the car to see if any attach points are visible. The car is about 8,000 miles from me at the moment.
    Kurt Geis
    Chairman, Midway USA Chapter
    Targa Blue 1972, Top Flight and Duntov Award, 2014
    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
    Arctic White 2013 60th Anniv Special Edition Conv.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: '72 lower ignition shielding
    The inter shields attach with one 1/4'' threaded bolt each into the block. The chrome shields attach with wing bolts to brackets mounted to the exhaust manifold studs. The biggest problem I have is if the brackets are not marked where thet go all of them look very similar but only fit where they are designed to fit.
    Lyle
      And, key 'tricks' to getting the installation right, is to closely view the assy sequence as called out in the U69 option section of your AIM book. THEN, when you go to put everything together, mount the lower shield L-brackets finger tight so they're still loose enough to move, but will still retain their position.
      Now, test fit the lower shields and move the brackets as required to achieve alignment for the shield attaching wing nuts. Remove the shields and final torque the brackets retaining their proper orientation.
      Then, you can go ahead and install the lower brackets. Tip: make sure you route the engine temp coolant harness through the RH lower shield and connect it to the switch BEFORE you commit the shield to its final mounting position and the insertion of the wing nuts!
