Test Firing of the engine after restoration - NCRS Discussion Boards
  • John M.
    • November 10, 2008
    • 364
    Aaaah,
    After a very long, arduous restoration I was finally able to test fire the engine.
    There's a lot of Blood, sweat and more Blood when you restore these pigs, but some times (on a few rare occasions) things sometimes go as planned.
    She fired right up with just a little pumping of the Gas. The choke worked as set, then she started to overheat slightly. Shut her down and add the last Gallon and a half of coolant, and refire her.
    Temp is good (cool actually) She purrs with a nice throaty rumble from the side pipes with instant throttle response rapping up like she wants to go.
    And best of all, not a single drip from any of the Tower clamps.
    I won't mention all of the headaches before this point, I'm just going to relax and enjoy something that finally went right.
    L46 350/350 Dyno'ed at 400HP 460 Ft.Lbs. (which might be because of the 383 Stroker kit and ported polished heads)
  • Tom L.
    • October 17, 2006
    • 1439
    Re: Test Firing of the engine after restoration
    Congrats! There is little satifaction until the long day has passed. Many more gratifying moments will come. Guaranteed. Have fun!
    • John M.
      • November 10, 2008
      • 364
      A classic example of speaking too soon and cursing yourself. I love it.
      So when I step on the clutch, there's a loud "Brushing" sound. I still have the car up on floor jacks, and can see the rear rotor stop when I hit the clutch, and moves when I release it.
      I have the clutch adjusted out all the way and am getting full engagement.
      But even slightly touching the clutch gives out a distinct "Brushing" sound.
      Pilot bushing?
      • John M.
        • November 10, 2008
        • 364
        Whew..... Another lucky one.
        I removed the Inspection cover and the "Brushing" stopped.
        That's a whole lot easier to deal with than a bad Pilot bushing.
        Enough for tonight.
