1967 Hood Support help - NCRS Discussion Boards
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 1967 Hood Support help
    Jerry, car or no car would still like to meet you and personally thank you for all the advice and technical help you've given me. Look forward to meeting you. If you come, safe travels down here. ARA
    • Ara G.
      • January 31, 2008
      • 1108
      OK guys, I checked my hood support yesterday for the part number. No part number. The ATWOOD and ROckfort ILL is stamped so hard in the one side of the support that you can see some of the stamping on the reverse side of the support. I looked high and low for a prt number, and nothing. Glad to hear from other members that I am not the only one with a support like this. I guess we will see if anyone else chimes in. THanks ARA
      • Howard W.
        • December 1, 1998
        • 122
        My 67 small block, Feb build, has both Atwood and part number. Atwood on upper inside of the support and the part number on the lower outside. I will also be in Kissimmee in Jan, probably be judging 67s.
        • Mark K.
          • January 1, 1983
          • 148
          My December build unrestored 67 has both the part number and the Atwood stamp.
          1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
          1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
          • Rick S.
            • January 1, 2003
            • 1203
            Well, after a diligent search I did locate the numbers on my June built 67, faint but visible.
            Rick
