66 oil dip stick tube - NCRS Discussion Boards
  • Ernest C.
    • July 31, 1991
    • 115
    The dip stick tube has broken off down at the block, and I can't get arip on it. Does anyone have any ideas how I might remove the end that is still in the block. Its a 327, and still in the car.
  • Dennis C.
    • June 30, 2002
    • 884
    Re: 66 oil dip stick tube
    Do you have enough room to try an easy out?
    Dennis
    • Ernest C.
      • July 31, 1991
      • 115
      Actually tried an easy out, but it would not budge.
      • Richard M.
        • April 1, 1993
        • 198
        Can you drop the pan and knock it out from the backside?
          Use a 1/4" tap, screwed into the tube just far enough to get some engagement, and pull it straight out.
          • Ernest C.
            • July 31, 1991
            • 115
            John, thanks we are tapping now, and then going to put a bolt in for the pull.
            Thanks again
            • Erv M.
              • February 21, 2007
              • 445
              Put some vasoline in the tube to catch the metal shavings
