Emergency 4 Way Flasher - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    I'm trying to find the part number for the switch unit (flasher) that would plug into the fuse block for the 4 way emergency flashers. I do know it is made by either Ideal, Tung Sol or Signal Stat.
    Also, is there a date code on the flasher unit and if so, is it judged?
    Thanks for any help.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
  • Pat M.
    • April 1, 2006
    • 1579
    Re: Emergency 4 Way Flasher
    I don't know what the part number is, but my 70 and a lot of early Sharks used an Ideal 536 Heavy Duty Flasher. There is a three-number date code, beginning with the year and then weeks of the year, so that "020" would mean 1970, twentieth week.
    I do not believe the date is judged, or at least mine never was.
    • Peter L.
      • May 31, 1983
      • 1930
      Terry - The 68-69 NCRS TIM&JG states that "IDEAL, TUNG-SOL, and SIGNAL_STAT were original manufacturers, and these are used interchangeably throughout production." As mentioned, the IDEAL 536 is probably an option or an IDEAL 552, or a TUNG-SOL 552, or a SIGNAL-STAT 175 are also some likely candidates. Pete
      • Terry B.
        • August 31, 1999
        • 607
        Thanks Pat and Peter, I appreciate the information. I could not find it in either the JM or the Owners Manual. Since the JM for '68 &'69 is up for review, maybe it should be listed there in the next edition.
        Terry Buchanan
        Corvettes Owned:
        1977 Coupe
