65 396 Dwell & Timing - NCRS Discussion Boards
  • Dave N.
    • June 4, 2009
    • 28
    Does anyone have the dwell & timing settings handy for a 1965 396-425 hp?
    thanks
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 65 396 Dwell & Timing
    I believe dwell was 28-32 and timing was 10 degrees. Hopefully somebody has the service manual to verify 100%.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Dave Nuti (50485)
      Does anyone have the dwell & timing settings handy for a 1965 396-425 hp? ..
      Here's two sources; The '65 AIM, K66 section, shows L78 at 8 degrees (+/- 1) @ 800 RPM. Since all L78's had T.I., dwell (in the traditional sense of points systems) does not apply.
      Notwithstanding the above, the Chevrolet Interim Shop Manual shows for 396/425hp (did the passenger car version have points ?) timing of 10 deg (range 8-14) and shows point dwell of 31 to 34 degrees.
      • William B.
        • April 30, 1975
        • 941
        If is is the corvette 396/425, it should be transistor ignition? No dwell
