online midyear birthday guide? - NCRS Discussion Boards
  • Thomas N.
    • June 30, 1998
    • 45
    Is there a online midyear birthday guide any longer? I know it used to be linked to the WI NCRS page.
  • Brandon T.
    • October 23, 2008
    • 872
    Re: online midyear birthday guide?
    If not whats your vin number I'll look it up for u I have a birthday book starting with 53
    • Bill I.
      • January 29, 2008
      • 554
      Brandon, would you be willing to do it for me also? It's a 67 vin# 194677S115851. Thank You, Bill.
      • Jeff A.
        • January 1, 2000
        • 312
        try the C2 registry
        http://www.c2registry.org/
        My Cars
        • Brandon T.
          • October 23, 2008
          • 872
          to the original poster
          "Brandon, Thank you for your help. Vin is a 66 coupe # 117564 march of 66?"
          Your car is dated for March 24th 1966
          • Brandon T.
            • October 23, 2008
            • 872
            No problem Bill.
            Your car is dated December 12th 1966
            • Wayne M.
              • March 1, 1980
              • 6414
              I too miss the Wisconsin site; other than the C2 Registry, mentioned above, here's another:
              • Bill I.
                • January 29, 2008
                • 554
                WOW, seems to be very conflicting dates here. I was told by the Dealer I bought from 3/28/67, Brandon's date is in Dec. 66, and that last site shows April 67. Who's to bless and who's to blame? Bill
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12888
                  Brandon,
                  Your car is dated: March 25, 1966 by the C2 Registry...
                  regards,
                  Rob.
                  Rob.
                  NCRS Software Developer
                  • Brandon T.
                    • October 23, 2008
                    • 872
                    I got my info from the corvette birthday book..it was right for my 68.
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Just be aware that the dates are just an estimate and may not be your actual date. The cause of this is that not all production days/shifts are reflect in the calculation algorithm. As an example, April 20, 1963, a Saturday, was a production day. This day is not in all the tools. The C2 Registry has it included.
                      A way to help refine the calculations is, if you have documentation as to the day you car was made, pass it along to the tool maintainer.
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Both sites previously mentioned concur with my trim tag.
                        Paul
                          Chevrolet production records indicate Feb, 1966 ended at VIN 115283 and Mar, 1966 production finished at VIN 118091. So, your VIN falls between these two production 'snapshots'...you simply interpolate to get its approximate final assy date.
                          NO system is perfect since to arrive at an absolutely correct date, the system has to remove non-work days from the calendar, comprehend any/all work stoppage events (rare), and consider any 'extra' work periods (e.g. added shifts, authorized overtime, Etc.). But, with a 1966 calendar, you'll get close.
                          What you do NOT want to do is go by the cars' trim tag! That date speaks to the body sub-assy build. With two body shops (AO Smith in Ionia, Michigan, and Chevrolet in St. Louis), there CAN be skew between a given car's body build date and its actual final assy date! So, you go by the actual VIN and Chevrolets end of month production records.
                          Happy calculating!
                          • Rob M.
                            NCRS IT Developer
                            • January 1, 2004
                            • 12888
                            I think you mix up answers here. The C2 Registry is calculating: Approximate birthday 194376S117564: March 25, 1966
                            regards,
                            Rob.
                            Rob.
                            • Rob M.
                              NCRS IT Developer
                              • January 1, 2004
                              • 12888
                              C2 Registry: Approximate birthday 194377S115851: April 8, 1967
                              Rob.
                              Rob.
