I have a 1965 4 speed M21 Corvette and the reverse lock out on the shifter is not working, meaning I can hit reverse without pulling up on the spring loaded lockout on the shifter. I understand there is an adjustment for this and would like to know how to do this. Any help would be appreciated.
Dave
Dave
). I picked these up at various swap meets shortly after I bought the cars -- didn't notice the differences, nor did I care at that time. The top/right T handle has the set screw and a thin shaft with a larger "inhibitor pin" end. The other has a rod that continues the thick part up to near the top, where it reduces to fit through the hole -- it is then flared to ensure it doesn't drop out.
