Are the base engine crank and water pump pulleys corvette only items or can they be found on other chevy cars/trucks?
I just noticed that mine are wrong. They are too far back and this has the fan belt running so close to the new heater hose that I installed that it is starting to cut into it. I took note of a 61 on the weekend and noticed that the pulleys are set about an inch or more farther ahead than mine is and has lots of room between it's heater hose and fan belt.
Any thoughts or advice on where to find some pulleys that will work for me would be appreciated. This is just a driver so they don't have to be NCRS correct, just function properly.
