I pulled my tire tub the other day to clean under it and check the general condition and noticed some mismatched bolts and some loose holes where the bolts attach the tub inside the carrier.
What are the correct bolts inside the carrier and what color are they? Also, what are the correct bolts and color for the bracket that the lock bolt attaches to? What is the proper length of the lock bolt for Gold Lines?
What can I do to close those holes up just a little bit?
Finally, on the subject of bolts, what bolt holds the antenna to the mounting bracket. Mine is stripped and needs to be heli-coiled, but I want to do it with the right thread for the right bolt.
); the bolts used separate flat washers (in spite of the JG description that says they didn't). Richard Fortier now makes the 1/4"-28 antenna mounting bolts Rich noted above.
