Can't Find Zerex G-05 Coolant - NCRS Discussion Boards
+ More Options
Posts
  • Brian K.
    • September 19, 2007
    • 174
    IS Motorcraft Premium Gold a G-05 equivalent? It seems to be but I can't confirm it.
    Thanks as usual!
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Brian G.
    • February 1, 2001
    • 159
    Re: Can't Find Zerex G-05 Coolant
    I just bought some yesterday at CARQUEST, $13.59 a gallon.
    List price......$18.21 a gallon.
    • Dennis C.
      • June 30, 2002
      • 888
      Brian,
      The only place Iwas able to find Zerex G-05 by me was at a Car Quest.
      Dennis
      • Alan D.
        • January 1, 2005
        • 2054
        Prestone now makes a one size suites all (I believe) may be less money.
        • Larry M.
          • January 1, 1992
          • 2702
          Thanks as usual!
          Brian:
          Yes it is the same. My reference is the Zerex G-05 website, where they state that Motorcraft Gold and Zerex G-05 can be used interchangeably.
          However, you should be able to locate the Zerex G-05 locally. NAPA sells it or can get, and the price would probably be lower than through FORD.
          Prestone Yellow-Green antifreeze would also be good. It is similar to G-05, but is slightly different formulation. Both are HOAT type antifreezes. But I would not recommend mixing them in your Corvette, unless an emergency.
          Larry
          • Jim D.
            • 2885
            It shouldn't be hard to find. Napa, Baxter, Schucks, O'Reily all carry it.
            • Jim T.
              • March 1, 1993
              • 5351
              I bought 2 gallons from my local NAPA store. It was not on the shelf. They ordered case and I had it the next morning.
              • Jeff A.
                • November 1, 2005
                • 199
                I recently purchased G-05 from National Auto at $10.99/gal. Unfortunately, in my area they only carry the 50/50 pre-mix, so I paid through the nose for shipping a lot of water to the store (but I needed it pronto for an engine break-in and didn't have the luxury of time to order the concentrate).
                • Ron N.
                  • August 18, 2008
                  • 243
                  Napa carries G-05 - on the self in Houston, TX.
                  Ron
                  • John D.
                    • December 1, 1979
                    • 5507
                    I also just bought two gallons of it at Car Quest.
                    • Brian K.
                      • 174
                      Thank you all for your responses. I found it at a Carquest!
                      66 Coupe
                      66 Convertible
                      2022 2LT Coupe
                      67 Chevelle SS396
