Default [!@#$% 1985 Digital Cluster] Need Context And Advice - NCRS Discussion Boards
  • John M.
    • August 31, 2003
    • 167
    The digital cluster in my 1985 has worked great for almost five years. I drove the car today and one of the elements on the speedometer began to flicker, recovered for a couple of minutes, flickered again, and went out. Cycling power did not change the behavior.
    If all elements are lit, the one missing looks like this:
    .. _ .. _
    | |_|. _|
    | |_| |_|
    (please ignore the white periods - spacing is interpreted badly by this forum engine)
    What's the likely diagnosis? To me, it seems like the element itself or its connection has gone bad, because the rest of them are still reading a speed that matches the bar graph speedometer. Two more questions:
    1) Is this something I can fix myself?
    2) If I can't fix it, who would you suggest to do the work?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Default [!@#$% 1985 Digital Cluster] Need Context And Advice
    John my ole 85 is still doing OK in this area. Have only had to replace the halogen instrument lamps. Real easy once you learn how remove the headlight swith knob.
    You could contact Gordon Killerbrew at www.gordonkillebrew.com and get some advice.
    • John M.
      • August 31, 2003
      • 167
      Originally posted by Jim Trekell (22375)
      John my ole 85 is still doing OK in this area. Have only had to replace the halogen instrument lamps. Real easy once you learn how remove the headlight switch knob.
      Jim,
      Thanks - I've been looking at the removal instructions and the headlight switch does look like the toughest part...
      • Jim T.
        • March 1, 1993
        • 5351
        Originally posted by John Mulhern (40669)
        Jim,
        John the whole switch does not need to come out. To remove just the knob on the stem disconnect the negative battery cable. Pull the headlight switch out and rotate the switch until the slot/cutout is visible (9 o'clock position). At the end of the slot, the open end you will see a piece of metal.
        With a small screwdriver push back on the piece of metal and the knob will slip off easily. The metal gives the friction fit to hold the knob on.
        The rest is just removing screws in the plastic. I remove the tilt lever, it just screws out. The front plastic comes out easier for me when I do. The plastic is just plastic and can be broken.
        • John M.
          • August 31, 2003
          • 167
          Jim,
          Thanks! That makes it a lot more clear...
          ...methinks the removal will be tomorrow. Not much time until the New England Regional.
          • Louis T.
            • July 31, 2003
            • 282
            Hi John,
            Best of luck!
            Louis
            • John M.
              • August 31, 2003
              • 167
              Originally posted by Louis Trohatos (40341)
              Best of luck!
              Louis
              Thanks for the advice, Louis!
              • Gary B.
                • September 30, 1987
                • 305
                When our `88 cluster went our dealer replaced it with a rebuilt one. Saved a lot of money.
