As far as I know the 1965-1967 Corvettes w/Muncie 4-speeds used only one set of levers (GM # 3864402, 1-2 lever; GM # 3864403, 3-4 lever; and GM # 3846891, rev. lever). Enclosed is a picture of the levers which I removed from my 1966 Corvette in 1980 during it's frame-up restoration. The 1-2 lever and 3-4 lever match up EXACTLY with the shop drawings in Noland Adam's 63-67 Corvette restoration book (pg. 292). I recently sold these levers (but have since returned) to someone with a 1966 Muncie 4-speed w/3884685 side cover and the levers would not fit because the slots in each lever (about 5/8" long) were two small for his 1966 Muncie transmission. Has anyone ever hear of another set of levers used on the 1966 Corvette Muncie 4-speed that use a larger slot (about 3/4" long, skeleton key hole shaped)?
I know that the 1969 and newer Muncies use the levers with the larger slot (3/4" long, skeleton key hole shaped).
