U69 front engine mount ground strap location? - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 993
    I could use some help clarifying a contradiction between the 1965 AIM and the 1965 JG regarding the correct location of the front engine mount ground strap location.
    The '65 AIM indicates that the front engine mount ground strap is located on the right side engine mount [U69, page A4].
    The '65 JG reads, "radio equipped cars have a ... ground strap on the left side only...
    Which is it? The right side or the left side?
    Thanks.
    Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: U69 front engine mount ground strap location?
    I would think there would be a hole in the frame near where the ground strap attached which would indicate which side it was installed on.....
    On a 67 it is on the left drivers side. Can't say what happened in 65
    • Tony S.
      • April 30, 1981
      • 993
      There's a hole on each side.
      • Stephen L.
        • May 31, 1984
        • 3162
        I just looked at my AIM for 1967. The REVISION RECORD on the bottom of UPC U69 A3 was drawn on 5-11-66. A revision was made on 9-7-66 from RH engine mount to LH engine mount for the location of the ground strap.
        Are both holes that you found threaded?
        If you look at the actual drawing on the UPC, can you determine the motor mount to be the left one based on FWD and the frame depiction??? and the engine mount was miss labeled which got changed in my above reference.....
