65 grill restoration thread - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    I am in the process of restoring 3 original 65 grills and was wondering if there might be any interest for me to post the process.
    Rich
  • Jim D.
    • 2885
    Re: 65 grill restoration thread
    I'm interested.
    Jim
    • Joel T.
      • April 30, 2005
      • 765
      Rich
      Rich;
      Me too, I have a '65 grill which could use some TLC.
      Joel
      • Ashley S.
        • November 1, 2005
        • 146
        Add me to the list as well...
        • James W.
          • December 1, 1990
          • 2680
          Rich
          Rich,
          Please do so. I am in the process of restoring a '65 and that is one thing on the list that still needs to be done.
          James West
          • Rich P.
            • January 12, 2009
            • 1361
            Hey guys thanks for the interest.
            I'll break this down into 3 or 4 different sections and it will take several weeks to complete, thats because the polisher takes 4-6 weeks and the anodizer takes a few days.
            First will be disassembly
            Second will be identifing an original grill from a repro
            Third will be chosing the right rivets
            Fourth will be the restoration of the center 3 sections
            And fifth will be assembly
            I'll log hours put in as well as out sourced costs, like polishing, plating, shipping and rivets. So at the end you can decide if this is something you would concider doing.
            Please ask as many questions as you have and also add suggestions you think might make anything easier.
            Rich
            • Rich P.
              • January 12, 2009
              • 1361
              First I'll start by listing all the tools needed to disassemble the grill.
              Hammer
              Cut Off wheel (w/3" wheel)
              Flat blade screwdriver (thin)
              Die Grinder (w/cobalt bit)
              9/32" 1/4" deep socket
              3/32" flat punch
              Also helpfull is masking tape to tape the aluminum surround while grinding the rivets.
              Rich
              • Rich P.
                • January 12, 2009
                • 1361
                Lets start the disassembly process. The first thing to do is to remove the rivets that hold the horizontal bar brackets. There are a few different ways to do this and I'll show just 2 of them.
                One is with a cut off wheel and the other is with a die grinder. Both ways have the same objective, to remove either the head or peened or squished side of the rivet. That is done so you can remove the bar brackets.
                Care must be taken so as to not damage the soft aluminum surround as that will be polished and reanodized later.
                You can see from the pictures that you just remove enough material to allow the bracket to come off.
                • Rich P.
                  • January 12, 2009
                  • 1361
                  More pictures of the rivet grinding process. This time with a die grinder.
                  • Rich P.
                    • January 12, 2009
                    • 1361
                    Now once you have ground all the ends off the rivets on the hrizontal bar brackets its time to remove them. Take the thin blade screw driver and hammer and then very gently tap the blade inbetween the bracket and grill surround untill it pops lose. Repeat this on all the brackets and remove them.
                    • Rich P.
                      • January 12, 2009
                      • 1361
                      Now that you have all 3 horizontal bar sections removed you need to disassemble the 4 grill surround pieces. This will be done in the same way as the center sections EXCEPT you need to be extra carful grinding the rivets down to remove them because you don't have the metal bracket to act as a buffer between the cutting tool and the very soft aluminum. Anyhow just carefully grind the rivets down like before and using the hammer and thin blade screwdriver seperate the surround pieces.
                      • Rich P.
                        • January 12, 2009
                        • 1361
                        More surroud seperation shots.
                        • Rich P.
                          • January 12, 2009
                          • 1361
                          Now that the 4 grill surround pieces have been seperated you will be left with a dozen or so rivets still in them. These will have to be removed in the same way by grinding them but this time you will have to use the punch, hammer and socket to remove them. Thake the socket and use that as a backing for the surround and place it with the unground side of the rivet in the socket opening then from the other side use the hammer and punch to remove the rivets.
                          • Ray K.
                            • April 30, 2005
                            • 409
                            Count me also. I've got two original grilles and I could use your expertise. Hope you can also help us in identifying where to locate a couple of my missing horizontal brackets . . . . . .
                            • Tom K.
                              • August 31, 1989
                              • 28
                              thanks rich, this is a great teach. i'll be following along
