L36 vacuum advance line - NCRS Discussion Boards
  • James B.
    • June 21, 2009
    • 28
    Did they run a hose from dis. to the carb, or use a steel line between the carb and dis??? like on the small blocks.
    Ty Jim
    • 43271
    Re: L36 vacuum advance line
    Ty Jim
    Jim-----
    A steel line was used. However, there was a length of rubber line used between the distributor and the steel line and another very short length of rubber tubing used as a connector between the steel line and the carburetor. The set-up was essentially the same as 1969 small blocks.
    • James B.
      • June 21, 2009
      • 28
      Jim-----
      Do you know how sells the steel tube, I can only find the small block line,
      Ty Joe
        • 43271
        Ty Joe
        Joe----
        Dr. Rebuild has it. However, I think the 69 small block and L-36 steel line are the same. The only difference in the set-up is that the rubber line connecting the distributor to the steel line is a little longer.
        • Jeff A.
          • November 1, 2005
          • 199
          James,
          FYI, I believe the correct original rubber hose had a prominent white line on it.
          Jeff
