GM '66 intake manifold gaskets 327 - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    Does GM currently offer intake manifold gaskets that are correct for judging with the tabs for 327/300hp?
    Ian
    Re: GM '66 intake manifold gaskets 327
    Ian -
    No, they don't. Paragon has side gaskets with the tab, but I'm not aware of any regular source for the rubber end seals with "GM" on them.
    • Dick W.
      • 10483
      Jim Gregg, a sometimes poster on here did have a few sets.
      Dick Whittington
      • Ian S.
        • June 30, 2002
        • 264
        Thanks for the info. Are there any issues with using an NOS set related to them aging and not working properly?
        IAn
          • 43219
          IAn
          Ian-----
          Not usually any problem. If there is a problem due to poor storage conditions, it will be more-or-less obvious. Plus, if there is a problem, it will almost always be with the side gaskets and not the end seals. In that case, use the end seals from the NOS set with the Paragon side gaskets.
          • John D.
            • December 1, 1979
            • 5507
            Paragon side gaskets. The camel hump has a verticle rib in it. Need to massage the rib. Make it go away. Very easy to do with a vise or small hammer. JD
