Re: New motor, light blue smoke
I had my 327 motor rebuilt and did the 20 to 30 minute break in to set the cam and a lot of smoke came out. The smoke went away but no power from the motor. I had to pull the timing cover to check the gear; it was off 12 degrees. Runs great now after I reset the gear. Your compression is good. Check your plugs after a brief run for oil. Before dropping the body run your engine a lot to make sure your are good to go. Check your exhaust tips for black deposits which means to rich. If plugs are wet with oil you probably have a valve seal problem; you can replace these without pulling the heads. I would be surprised if the rings are the problem. Good luck.
