Trunk Drain Hose 1961 - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    There are two drain hoses down-spout hose connections in the rear V-channel of the 1961. One of the tubes is missing on my project 1961. I would like to make one, could someone please tell me what material the tubes are made of?
    Thanks! Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Mike M.
    • May 31, 1974
    • 8390
    Re: Trunk Drain Hose 1961
    the wall thickness of originals is much thinner than the walls of readily available fuel or vac. hoses stocked by NAPA etc. did you try Dr Rebuild? he has unique hoses. good luck and let us know if you find a source. mike
    • Ray C.
      • June 30, 2001
      • 1132
      Hi! Mike
      I have the original hoses, the information I am in need of is the male tube that is attached to the body and the hoses connect to. It looks to be attached to the body using bonding adhesive.
      As Always!
      Thanks for the help
      Ray
      Ray Carney
      • Joe M.
        • February 1, 2005
        • 590
        Funny how those drain hoses look exactly like the thin walled FI nozzle block hoses.
        Made from darkgray/black fiberglass tubes it seems.
        • Ray C.
          • June 30, 2001
          • 1132
          Thanks!
          Ray
          Ray Carney
